mrvette
Phantom of the Opera
Are we talking about ball joints or control arm bushings? This is the picture
Look at post 5 of the "Finding the center of a ball joint" thread in this section
I must be missing something. I've never seen spherical joints on control arms (if you are talking about the pivot joint). What is the purpose of spherical joints on a shaft?
Is there a link you can provide to the Duntov part?
The control arm spherical joint -- for the inboard pivot of the control arm, not the ball joint end -- is pictured in the right-center of the attachment. The spherical joints "on the shaft" as you describe take all of the deflection-compliance out of the control arm pivot for more precise suspension geometry. Not very comfortable for a street car.
Pappy
So you consider that removal of last 5% of bushing flex worth it?? I mean the urethane hardly give at all.....:surrender:
Absolutely, for a pure track car with 12.5 in wide front tires. I also have "slugs" that can be changed out to vertically adjust the inboard pivot points to adjust roll center, anti-dive, and/or caster gain -- no single shaft between the fore and aft pivot points. The spherical bearings accomodate those changes quite well.
Pappy
:smash::smash::smash::smash: Gotta LOVE it, best of luck....lettuce know your results.....rather interesting....
