Correct plumbing of Filter regulator
donnie_19
Troy, MO
Can filter regulator be mounted vertical
Only have seen them mounted horizontal but does it matter?
You can mount the regulator vertical or any other direction. If it is a normal type filter then it relies on gravity to trap water in the bowl so it should always be mounted horizontal. If its a decent type dryer then it could be mounted horizontal. Another suggestion is try to find the manufacturer and model and google it to see what they recommend. Hope this helps :drink: Mark
No kit just the filter and it has a bracket attached but no instructions. Mounted to the frame rail in rear.
I can tell you horizontally, with male in, female out works fine. Are you wanting to mount it vertically? If so, I would suggest the outlet be pointed up, simply easier to bleed air out.
