badbirdcage
The way you straighten the mains for finish is you grind them straight. That way they are stress free. When you push a crankshaft around in a press to attempt to get it straight you induce stress into the shaft. And yes, the flywheel flange should be machined perpendicular to the mains. You do that with a lathe, aligning on the main bearing surfaces after the shaft is finish ground.
We always used to stand crankshafts on the flywheel end or hang them in a rack from the flywheel end.
Rich:beer:
But, it had to be straight when it was ground new. Would you not be just taking the sag out and returning it to the "as new" posture?
If I understand the OP's question that was the purpose. To straighten the main bearing surfaces back out.
Have you ever taken a new GM tufftrided crankshaft out of the box and put it in a set of V blocks to check straightness and found it to be two and a half thousandths out of alignment from the front and rear on the center main bearing surface? I have; more than once.
On an aside note: Has anyone considered the energy generated and sent through the crankshaft while it is in operation? Things get out of square really quickly in a dynamic operation.
We used to have a couple of customers that wanted us to grind crankshafts in advance of factory index on the rod journals so that the piston would be in proper position in the cylinder when detonation of the fuel took place regardless of the twisting of the crankshaft.
Rich:beer:
