SmokinBBC
So you have the same problem with 2 different dist. and carbs?
I second a check of the valve springs. Also when you are checking the timing does the light "wander" or is it rock steady at a given rpm?
Gotta be springs, they hitting a harmonic in there where the coils are in a bind, lucky they maybe not broken....here or somewhere I seen high speed movies of that shit, them springs going every which a way but loose,
talk of a devious SOB, damn.....:search::shocking:
I just checked this post out tonight and must say, from your video it looks like you have valve problems. Most likely from the springs.
That is why when you keep the car running wide open and it starts to die you see the gas vapors shooting up through the top of the carb every time it dies.
Your valves arent acting properly and you are getting compression back through the intake. Thus pushing the gas vapors back out of the carb.
But that is my .02 cents.....its all trial and error from this point. I would rule out distributor and carb problems though.
:hissyfit:First I found the cam 4 teeth off.
The guy who owns the shop that I'm using for the build saw the Youtube post and said "reversion". Check the cam timing. If nothing else it was a great experience.
Blain
