MYBAD79
Moderator
I sanded the bottom of the car a bit, contouring the floors is hard but worth it in the end since once undercoating is applied won't be able to tell there was damage. This side is by far the worse, you can see where I accidently over sanded and made a hole. I still have to lay a good 5 layers inside and probably 4 on the bottom of the car but it should be a strong repair when done.
You're sure you want to use that nastiness ??? Rust is not an issue, use some primer and flat black paint - it will look a lot nicer :thumbs:
