phantomjock
...A while back I had some axles shortened and balanced. This was at a driveline shop that primarily does trucks. However, the guy I talked to had lots of experience with car stuff. I was talking to him and he pretty much told me that anything was possible as far as adapting and converting. And all done with catalog items.
You might wan't to find a driveline shop close to you and show them what you are after.
Roger That! I'm trying to do some homework and get ideas before I sound too stupid at the local shop. There's one a mile away and my engine builder is a few blocks and an excellent machinist.
Looks like you have done way more homework on this than I have but, I seem to recall, you can pull the inner CV joint off the stub axle and buy a splined yoke for the u-joint. Presumably that is welded on to the axle stub.
Sound like that could be the easiest solution, but would be a mix and match of CV (outer) and U-Joint (inner) on the half shaft.
-- but I have not found any reference to that yet, anyone else have thoughts on this issue?Originally posted by rtj
... I don't think you want to mix unjoints with cv joints. U joints have a cyclic torque output unless at 0 degs. That's why ujoints are supposed to have similar angles at each end.
Ahh - but it just occurred to me - I'd loose the compression aspect of the inner CV joint... hmm back to the garage with another cuppa...
Thanks! Jim
