73 Mike
I'll drive it someday
Not car related but electrical. Since there isn't a hot tub section, I thought this was better than OT.
Every summer, I shut down and drain my hot tub. We don't use it much in those months and it costs me almost as much to heat then as in winter. Every fall, I refill it and spend some time trying to restart it. The problem is that the ground fault fuse keeps tripping. Typically, I disconnect all of the accessories from the control panel, run a heater/fan on the panel for a period of time and then I can coax it back on. Once it's running, the heat generated within the control panel keeps it quite happy. This year is different.
I just can't seem to get the ground fault to stop tripping. I've tried to isolate the issue and believe it is within the panel itself. Using my sophisticated knowledge of electronics (one step better than using a wet finger to trace hot wires), I'm fairly sure that the problem lies either in the panel circuits or the remote control panel. My problem and question is I don't really know how to chase a ground fault.
Any tips or suggestions?
