I'm a little confused here.
You replaced a bad 2 pole 50amp GFI with a 30 amp rated one?
Or was the 30 amp in the main panel feeding a branch circuit with a disconnect box and a 50 amp GFI?
I've seen a lot of these wired incorrectly, but have never seen one with electric heat that required less than a 50 amp circuit and 6 ga wiring.
Mine is on a 60 amp circuit, but GFI's weren't code back then.
