:trumpet: That is FANTASTIC Weight Redux! :trumpet:
Market that product! Near 50#s per side. WOW.
Something to be proud of.
Look forward to your driver entry/exit review.
:beer: Jim
Karsten, Have a question about removing and re-installing the doors (with the front clip on). Did you remove the hinge bolts holding the door to the car or the bolts holding the door to the hinge? Or, does it matter? When installing the door, are the hinges mounted to the door or the car?
Made another mistake...... the doors must be unbolted from the hinges first, can't get to the bolts that hold the hinge to the A pillar..... My initial plan was to leave the hinges bolted to the doors and swap the hinges with the doors, too bad that won't work....
Maybe I should have looked at this before I bought another set of hinges :crap:
I didn't know that. I have kicked around removing the steel shims on the hinges and replacing them with a similar thickness piece of aluminum.
Thanks for the info.
How the hell did you get to the top hinge bolts? They look hidden up under the dash.
not all that bad actually, a 4" extension on a 1/2" drive ratchet and a 9/16" socket .... That's to loosen the the bolts , during fitting and adjusting the door I just used a 9/16" deep socket and my 18V impact driver .... No sweat .....
