The original 75 HEI advance mechanism froze up and it wouldn't advance. I guess this was a common problem with just the 75s. The current HEI is a 76 out of i don't know what. I bought it at a garage sale in the early 80s. I would guess this unit has 300k miles. The new weights with installed bushings fit very snugly over the posts so they hadn't worn at all. The plastic keeps them from wearing.
My engine runs best at 32*. To get that I have to run 19* initial, then I get
13* from my HEI dist. Is there any way I can get more than 13* from the dist so I can run less initial?
TIA
R
Sounds to me like you're fixing the wrong problem. Replace the balancer with a new one, better yet, get something like the Streetdampr where the ring can't slip and it's marked out to 45* from TDC. Then set the base timing per Lars' paper and fine tune from there.
If it's a good unit, change the cam and weights.
OR, if it's iffy, or worn, order a new unit from DUI, built with a 20* Chevy power book curve.
http://www.performancedistributors.com/
Is this the settings you were talking about with me last time Jeff?
pictures of the redneck mod as promised. The flat section of the weight that limits advance has been ground off, so it just keeps advancing until the weights hit the inside of the rotor.
don't try this at home. You guys know i'm out of my gord.
The weights i pulled off of my spare dist do not have plastic bushings and fit loose on the posts of this dist. I'll have to drill them out to accept the plastic busings. They are much thicker and heavier than the other weights and are stamped 60.
I was looking around and found that MSD now has a 20 amp coil and module.
OH, edit, I have never ever seen one of those green circuit cards in a HEI, always the TPI type or the old black OEM sending chips....WTF is that for??
Before I start messing around and possibly cause more problems than I am trying to fix:
Does my dist being all advanced at 2800 sound like it has a problem?
It looks like it is working properly, am I wrong?
R
R
Most say 3000. Close enough. I'd leave it be. Is it pinging?
R
