LS
I have an LS 6.0 bored .030 over engine with FI , 317 heads, 2800 stall converter, 2004R with shift kit, Holley ECU. I have the torque converter lock up wired using the brake pedal to unlock.
Judging by the comments here, a stock f body or C5 LS6 with a 4L60 trans and stock 2.73 rear shouldn't be able to get out of its own way or maintain OD at hiway speeds.
Stock cam is somewhere around 210 duration, stall is what ? 1800??? My LS2 runs fine at 1800rpm but that's with stock cam and a 6spd .... With a cam in the 240's duration it will not run great at 2000rpm ....
Not trying to sound like an ass but doing things over is expensive as I learned the hard way .... A few more details from the OP would help ... LS1 with FI or carb? Heads??
