Not internal aero related, so I'll apologize right now, but this seems to be the thread that might get more input on my question/project. I'd like to put a small, as-non-obvious-as-possible aero mod to the area between my hood scoop and the windshield. My goal is to "stall" more air at the cowl area for several reasons. These reasons include a little more static pressure in that area for increased downforce on the center of the car, increased drag on the windshield to help slow the car when braking, and what the hell, the increased pressure behind the scoop opening might help the carb air intake quantity/mass a micro amount to help offset the increased drag of the aero setup.
Right now the easiest thing to do would be to remove the cowl grill strip, and replace it with a (painted) aluminum piece that has some tabs on it that would stall/spoil the air flow before it reaches the windshield.
I'm just beginning to kick around some ideas on the form of this thing, but any suggestions or caveats are welcomed.
Ok - I've been trying to get my head around the idea - see if I am close to understanding where you want to "stall" [I think you mean increase the pressure - or stagnate] the flow?
Here is some interesting work done on the C6 Racecars:
Note the hood is shaped to move the high pressure towards the A pillar --and off the windscreen.
Another view:
I couldn't find a CFD of a C3 so this volvo will have to do:
Some of the clear VGs available would be pretty unobtrusive to test out: https://www.aircraftspruce.com/cache/400-400-/catalog/graphics/05-04457.jpg Aircraft Spruce is the source.
Make new rocker moldings out of thin aluminum which are 1 to 2 inches longer. This will act as side skirts keeping flow out from underneath. Lower is always better for side skirts.
Creative use of black paint could disguise how low they are.
Also, the spare tire area is a mess, a diffuser would be too obvious for your goal, at least a smooth under belly would help.
Yeah - Ok I got it now...
I thinks the challenge; "... lies not in our stars, but in our "cars"..." Sorry Shakespeare
The car presents itself as an analog of a wing. So getting a high pressure over the top of the car would take some real doing. Consider the following comparison:
A vert may have more potential downforce over the center of the body - due to turbulent flow -- maybe not.
Hopefully the image shows how the shape acts like a wing and creates low pressure on the upper surface -- just like a wing.
The question might be changed from; "How do I create higher pressure on the top of the car", to; "How do I get lower pressure underneath?" It is really about the differential in pressure.
The underbody offers many "unseen" opportunities to create a low pressure area(s) and place it where you want - center of the body. You'll give up some ride height - maybe - but it would be unobtrusive and should be consistent throughout a speed range. That is to say - no pitching moments as you accelerate/slow down.
Your Pace Car style front spoiler should offer some help in the corners you mention. Additional drag through "Active Aero" would also play well for braking - but not all racing associations permit these.
Hope that info is useful.
