phantomjock
Ralphy -
Clearly correct: The double wishbone is the optimum (to date). I wanted to work on the Giovanni set up and am planning to continue - along that path for the time being.
The interesting thing is, the reports of the setup have belied many of the theoretical critisims. So, when I, Get-er-Dun - I'll take it for a spin and let the tale be told.
But, all the discussion has given me pause to consider a few modifications.
I will revise my Giovanni. I'm not yet ready to scrap it entirely, and it will be a major improvement over teh stock C3. I plan on removing the Chassis Tabs from the inboard locations, and replace with a more adjustable set of C Channel drilled with several alternate locations.
AND, I'll adopt an approach used by Twin Turbo to bring the lower struts into the same plane as the upper and the Half Shafts:
More details when I get back to the shop and get some work done.
Meanwhile I'm going to start another thread where I'd like to discuss mating a C5 rear suspension (Double Wishbone) to a C3 Chassis!
