Denpo,
A good book is the book from D. Vizard on Camshafts and Valvetrains (chevy). I have it here. It tells you almost anything you need to know, from crunching the mayor numbers to the relationship between CR and cam timing, plus some things like spring pressures etc.
This will only leave the most in depth analysis on the table, being things like jerk, mayor intensity etc.
As for this cam : yes it has a lot of overlap. To note here is I run an ITB on FI. so the overlap will not be as much of a problem like in a 4 barrel app. Seen the fact I don't have a plenum I cannot run on engine vacuum for brakes and such and will have to employ a vacuum pump.
Furthermore, both engine, trans and rear end prefer high rpm's. Cam is geared towards higher rpm (3000-7000).
Mike asked me the specifics of heads, valvetrain, CR, induction and such and based on that provided the cam. Although a very good piece, price was the same as a custom cam from the mayor manufacturers which whom I had less succes.
As for the inverted flanks : the cam is lazy off and on the seat. I assume this was done to minimize valvetrain/seat problems (47° mayor intensity). then it picks up speed due to the inverted flanks, to keep the valve longer open at maximum lift.
Overlap is 120° (seat timings) which is huge in my opinion as well, but could work in this app.
This is a tight lash cam also.
Seat timings at .012 are 292/296, @0.050 245/249.
Rpm max should be close to 8000.
I know it's maybe a bit to much racy, but then again I do not run her as a DD.
