mrvette
Phantom of the Opera
I see, kind of gives the lifter a "primer" start to the lift allowing a smoother transition and an overall more stable high lift situation right? Thanks for the info!
I don't think so. The idea is to simply keep the valve fully seated until the last possible cam angle.
Maybe Belgian could post more pictures. I'm curious if the trailing profile is the same. I would think so allowing the valve to completely seat as early as possible.
The most ideal profile would be closest to a square. The only way to create that would be electrically operated valves.
Better than mechanical, but never be totally square....
wonder what ever happened with that concept of desmodromic (sp?) valves, like a rotating ball valve setup, for fuel and air??
think the had a prototype running with it long time ago but forget who was messing with it....
:ill:
