Gene is correct. I have more imagination under the hood than actual stuff.
In any case, I am currently slowly ripping apart the front of the car working towards fixed fia headlights and a new bumper.
Till then I am imagination land. I see people that buy these things and nobody ever really describes what they actually DO.
In any case: This is the current thought.
355 with a forged crank, H-beam rods
Dart Pro 1 200cc platinum heads with the CNC port matching, bowl work, and chambers, and a cooling port added underneath the center exhaust port.
Pistons will depend on the volume the CNC porting adds. The goal is 11-11.5:1 compression.
The camshaft will be a GM 12370847 camshaft 234/242 at .05 on a 112 LSA. Its a Crane camshaft, and every reference of people who use it say its a decent hot-rod cam. I also have some 1.6 ratio crower roller rockers, OE hydraulic roller lifters, AFR Hydra-Rev kit, I am open to suggestion on push rods.
According to the handy dandy DCR calculator it says that this should have a good 8:1 DCR.
Edelbrock RPM Airgap intake, mainly because it has rear coolant ports and it did better on Grumpy's intake thread than the dart intake did.
Speed Demon 650cfm with vacuum secondaries (Based upon the barry grant demon selection guide and the cam card). The demons have down leg boosters in the 650 cfm carbs which is hella better than the straight boosters of the holley 650cfm carbs. Both the Holley and Barry Grant selection guides say vacuum secondaries.
I have a nice set of hooker side mounts that I got used for a song.
Cooling is the fun part:
Coolant ports under the exhaust ports
rear coolant ports attached to a moroso waterneck like Gkull has
Stewart Stage 3 waterpump
dewitts radiator and electric fans
Oil cooler with thermostat
fuel cooler (maybe)
Ignition:
Mallory Hyfire 6AL box
Mallory Distributer
Mallory 29440 55000v coil
Mallory High Pressure Fuel Pump and pressure regulated fuel log
Titan Speed oil pump with custom oil pan and a Milodon Diamond stripper windage tray
Clevite H bearings
I am thinking that with my M21 I would use a 3.9:1 rearend ratio, If I get an aftermarket transmission I would get the M22W from
www.5speeds.com I would go to a 3.36:1 rearend.
