Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
I made kind of a study of C3 driveline angles a while back and have never measured an engine angle less that 3 degrees. Most are 4 degrees. Also, I don't know how cutting the rubber isolator on the diff will rotate the nose up. Cutting the rubber actually rotates the nose down.
No, thinning the isolator moves the pinion up, reducing the pinion angle. The diff hangs under the frame, not on top of it:
