LT1 intake and 200 4r trans....
mrvette
Phantom of the Opera
NE Florida
Need a throttle cable bracket that mounts to the side of the manifold...behind the t-body.....the trick is....it has to have the obvious throttle pedal, cruise, and then trans kickdown cable for a 700=200 cable....
did GM ever make such a thing??? as of now, I have a suspect I need make one up custom.....PIA....
:crap:
As far as GM don't think a 2004R was ever an option with LT1. I have the adapter that came with my Lokar cable kit for LS swap. http://www.tvmadeez.com/ls1_cam/ I will get a photo for you later today. You may have to modify or copy this.
