mrvette
Phantom of the Opera
That oddly shaped hole is only present in the steel insert glued in there, not in the fiberglass at all! It's shaped like that so that the same steel insert can be used on both style cars, same firewall apart from drilling pattern and bolted down pedal box. The reason for the top to be narrower is that the hole that the master engages in is much smaller than the large hole for the brake booster harmonica seal. Those pics are misleading to say the least. The outlined part is a steel plate! I know, I took all that stuff apart when I fixed my firewall and bonded it all back together again later. I'll see if I can find my old pics, it's clearly visible on them
That is funnier than my harmonica balancer concept.....:lol::lol:
