More stuff to do
Help
When I was pulling everything apart, I noticed the gap between the defroster duct and the vent box (center of photo below). Is this normal or is there a missing piece? :crap:
Bump
Anyone have any ideas?
Everything is out. Time to clean it up and put it back together.
That's some scary shit right there - I have that to come yet...
Unfortunately, It gets worse before it gets better! Lots of new wires with the alarm system, EFI conversion, electric fans and H4 headlight relays. I am making some progress....
thum_7944b25260531b42.jpgthum_7944b252605dc9b2.jpgthum_7944b2526058e7a3.jpgthum_7944b25260639082.jpg
I would tape up the ducts but I think the lower part is sagging, it has a tab that screws to the firewall or the top part..forgot, been a long time since I pulled the heater out of my 82. They fit a lot closer together but there's always a gap so tape or foam should help.
Now that you have it all apart, think dynamat, fatmat, noize killer, whatever. Costs a few $$$ but the results are awesome.
Thanks for the info. I believe your memory is correct. I loosened the defrost duct and closed the gap with some adjusting and I can seal it with duct tape. I think the duct just got a little warped from the heat. I installed the Hush Mat.
Finally getting back to work. I got side tracked putting the old motor in a friends Blazer.
It cleaned up nice and it is running great.
Started putting the new engine back together
Making some progress
That's why I'm asking for specs... those pistons look like low CR dished stockers.....
blower ????
That looks like great project. All quality stuff. About the alarm. My big concern for my '65 is somebody hauling it away with a tow truck. Has there been any late developments in the gps anti theft concept lately?
Pistons: SRP 383 1.26 compression height - 9.8 CR with @ 9.01 with 64cc heads and 5.85" rods
Block is decked to 9.013 and so I have a .043 quench with the .040 MLS gaskets.
Didnt think I could get away with higher CR as I have cast iron vortecs and the need to pass the smog test.
I think the GPS technology has come a long ways. The Onstar system is amazing but the monitoring can be expensive (but well worth it for a priceless 65).:bounce: The pager alarms (pages you if your alarm goes off) can warn you if you are close enough to receive the page and have the ability to react.
RJ80;64911. I think the GPS technology has come a long ways. The Onstar system is amazing but the monitoring can be expensive (but well worth it for a priceless 66).:bounce: The pager alarms (pages you if your alarm goes off) can warn you if you are close enough to receive the page and have the ability to react.[/QUOTE said:
My problem with monitering is whpo chases the thing when it`s leaving town:confused: I don`t think our police have any tracking devices for that stuff.
I kinda like the beeper if they`re any good `cause I definately have the ability to react:smash:
383
Engine is done...:)
Another shot
383 sbc 4 bolt, 1pc rear seal
Lunati sledgehammer 3.75" crank
Manley 5.85" sportsman rods
King bearings
SRP 9.8:1 pistons
Total Seal file fit Gapless top rings
Mild Ported Vortec Heads with screw in studs, Comp Cams Beehive Springs
LT4 hot roller cam with 1.6 roller rockers
Air Gap Manifold
Fast EZ EFI
Mellings select pump, canton pan
DUI distributor
Hedman Hedders
