I haven't done much to the car due to health problems but currently now have the correct rotors to do the J55 brake upgrade. I will have to rebuild the J55 calipers since the rubber boots are torn. I'm going to hold off on suspension rebuilding until I am sure this car can drive. so after brake issues are fixed I will get it setup for smog and hopefully it passes. I've also been considering a color change to metallic blue with silver GS stripe that matches my rims.
I started sanding down 1/2 the hood and drivers door today. I am not bothering primering the car since eventually it is going to have a color change anyways. For now just want it one shade of white.
So after I break though clear with 220 with block sand the original white base with 400 and 600 and then spray and clear.
I have a couple high/low spots but just going to fill them. I'm not overly concerned about the door jambs though.
today I sanded down the headlight lids & bezels and started on the passenger door. By tomorrow I should have it prepped enough for a new coat of paint. I know primer is the best way but since a color change is in store for the car it's original white paint is going to be the primer hahaha.
today I had the dreaded hood cable break and what a pain in the rear. It even looks harder to replace the cables for that matter. So being I'm cheap I just got two clothes hangers and made my own releases. Works great and actually easier then bending over to unlock the factory hood latch release.
drilled the hood latch
drilled the rubber hood seal
bent my clothes hanger and afterwards bent the tabs down
