Those are not simply spacers, take off the JB weld junk and have that welded. Last thing you want is the bracket to be able to wiggle and break off the batwing too, you'll instantly loose that whole suspension corner.
That's where some cases are weaker. See the difference in "meat" around the bolt holes? The one on the right is the thinnest in that area
Next time you bolt the batwing down, use one of the camber bracket bolts on each side to align those holes. The batwing bolt holes themselves have enough oversize to move the whole thing around a bit.
Why is everything so super clean under there? Did you powerwash it?
Looks like it's leaking from the pinion nut? Someone forgot to add permatex to the splines.
I repaired the broken C beam mounting pad on my ZF6, it can be done by a competent shop without any major issues.
The tailshaft section on the ZF is easily removed, all you need is a new seal and gasket, can get those from ZFDoc no problemo.
John not so lucky on that one though....thing is, setup in a new case is more of a PIA than welding that case....cant win....
:skeptic:
:skeptic:
Welding is cheaper too.
So.....I get a call from driveline guy. My yoke is shot, and I need a new yoke....$80...$$$ $$$....
Now, can't just have a new yoke, oh no, you have to now get a new bushing in the trans to support the yoke. Call Trans place. No price but still $$$$$$$.
Where does it end?
Where does it end?
Where does it end?
It ends when you sell the vette............................and starts up again when you buy the next vette, 69 camaro, 66 mustang, etc, etc, etc.........
DId I mention I have a boat too? My wife is ready to kill me. Seriously.
just sell the boat and buy her some jewelery ... spend the difference on the Vette...![]()
Or better, spend it all on the vette![]()
That was my first thought, but he's got to keep her happy.
