JeffP1167
CFI is batch fire anyways just run same ignition feed to both injectors. I've never seen a resistor in CFI harnesses. I think it's just a crimp type things for the injector wires.
What about the return (pink wire to the dist)? Are the injectors grounded or something?
Thanks TT. So I should just leave the Duel Inj Select terminal disconnected at first? ...I hope it revs without the VSS, or I might be sort of screwed.
