oddball engine concepts
If I remember the article correct. The motor was in a Corvair. It sorta reminded me of a pancake motor in a Aurora HO car. Except it was in the rear. Good question about the spark. I would guess there was a pickup the plugs would pass by.
About the only way they could have much chance, any igniton depending on some roller/brush contact to ME would be not capable of integration on a reliable basis....
(nothing to do with race relations, unless you consider commutators and brushes).....
:clap:
Anyone have a picture of the old Willys slide valve engine? Now theres a mech nightmare.
Last week I got to spend a few hours in the "experimental" section of the Air Force Museum.
Here is an interesting engine - Pulse Detonation Engine - built by Scaled Composites - Burt Rutan and company.
Interesting concept. Welding 2 automobile engines together to "fire" a pulse. They mounted it in a modified Vari-Eaze, and flew at 250+ Not much goodness for most auto applications - but interesting reversing from a closed combustion - to open for thrust! Reminded me of a spark plug in a tailpipe running carbs rich on a Saturday nite!
Jeebus, looks like that Datsun across the street from a few months ago....whata nitemare......the devil won on that round.....
:twitch::surrender:
Jim, here's your spark plug in a tail pipe.
[ame]http://www.youtube.com/watch?v=n9Xhut_nqBE&feature=related[/ame]
The engine (rotary) on the Sopwith Camel of WW 1 had the crankshaft bolted to the airframe and the propeller mounted on the crankcase. The cylinders and main case all were spinning when it ran. No real carb on that one either- power was controlled by switching the ignition on and off. And it ran on castor oil.
Overall, it makes a good case for why to balance an engine.
I remember that. I have gotten into arguments about that engine/plane. It was said that plane killed more pilots than the Germans did. Had a really hard time turning in the opposite direction of rotation (if I remember correctly) but could turn unnaturally tightly in the direction of rotation. Most pilots were young, inexperienced pilots, tried to bank on take-off and plowed in the ground.
Another one I remember is the 500 cc. oval piston Honda. The reasoning was to allow for 8 valves per cylinder. They spun the thing at around 20,000 RPM. It was said, it sounded like a 2 stroke. The bike had an inherent issue of wanting to lay down. This is a 750 I guess.
http://thekneeslider.com/archives/2010/11/01/honda-nr750-oval-piston-32-valve-v4-for-sale/
I remember when that came out also. As I recall, it was Honda's answer to the 4-cylinder restriction in championship bike racing. It was basically a v-8 with 4 siamesed pistons. Crazy shit.
The problems with turbines for highway use--
Noise
Heat
Fuel Consumption
Heat
Not real complicated to run, the latest stuff is pretty much "push the button MAX!" Full FADEC control so the operator is more of a monitor than a participant.
At full throttle, the exhaust runs around 915* at the end of a 4' tailpipe.
According to Jay Leno, who owns one of the surviving Chrysler Turbine cars, they had most of that solved in the 60s. He says the exhaust on his car is no hotter than a regular auto exhaust, and it's not particularly loud.
Noise
Heat
Fuel Consumption
Heat
Here's a pic of the engine I took at Petersen Museum last week :
[ame]http://www.youtube.com/watch?v=kO-eLvzqWyM[/ame]
[ame]http://www.youtube.com/watch?v=WID-WH27J1c&feature=related[/ame]
Doyle Rotary Split Cycle
[ame]http://www.youtube.com/watch?v=lJ1kxbtsBSU&feature=fvwrel[/ame]
Variable Compression Ratio Car Engine: MCE-5 VCR-i
[ame]http://www.youtube.com/watch?v=DdM2VbbdtB4&feature=related[/ame]
