SuperBuickGuy
Does the stewart pump have the bypass in it?
(small hole on the passenger side under the mounting bolt)
![EDE8810-L.jpg](http://www.behrents.com/mm5/graphics/00000001/Edelbrock/EDE8810-L.jpg)
I was reading your post on SpeedTalk and was wondering.
Why are you using a SB2 pump? The normal outlets to the block are usually blocked on those although on some pumps they can be removed, others don't have the hole at all. The side outlets are for running -12 directly to the side of the block, something no std. block has unless you drill it ?
I assume these are the pics of the pump?
I have a similar pumps, one from Stewart and one from Adams. I didn't even know you could order it from summit???? Also, they tend to have the larger pump shaft so the stock pulleys will not fit, although a 19mm drill will take care of the pulleys since it's a 19.2mm hole that you need.
SBG, the pump doesn't have the hole. You need to use their thermostat with 3 vent holes in them for that.
I got lost on that.... you used the word "their" do you mean Stewart's or Edelbrock's?
the reason I ask, if the pump was spinning dry, that could be the cause of the failure of the seal...
Stewart's.
No it has not been spinning. Spent it's life in a box after I received it untill I used it to mount it on th engine.
