bobs77vet
wow, i missed those shiny new parts those are nice!!
Yes, I will fiberglass the taped areas. That then becomes a male mold which I will finish sand, wax, coat with mold release, and pull a finished fiberglass part off of the outside. That gives me a smooth finish for the exposed surface of the duct which I will then glass in place in the air dam. I'll take a couple of photos as I go.What is the next step? Fiberglass the taped surface?
I'm really interested in what you are doing. I will have some similar things to do with my car.
The poster board is under the yellow tape. I just formed the scoop out of taped together pieces of poster board, then covered the whole thing in tape to give it some rigidity. Then I covered the yellow tape with clear plastic boxing tape which releases the fiberglass resin much easier than the masking tape. Finally, I waxed the clear tape and put on a final coat of PVA as a mold release agent. Once the fiberglass cured, all of the tape and poster board just pealed off the back side with no effort . The tape does leave some lines in the fiberglass, but they are shallow and easy to sand out. Here is a photo of a poster board and tape buck I used when I built the fender flares for my Focus track car, to give you and idea of the build-up.Is the poster board under the fiberglass mat?
Correct on the lines. The yaw sensor and wheel speed sensors are electrical connections, and the electrical input block on the control module can be seen on the far left in the photo. The connector is not plugged in in the photo, but it is pretty massive with leads to not only the yaw and wheel speed sensors, but also to the power switch, ground, performance warning light, an adjustable function switch, a CAN bus connection for the ECU, and a connector for a cable that is used to hook up the laptop. You program the control module for all kinds of variables like wheel diameters, corner weights, track widths, etc. Yes, it controls all four wheels. I had to switch out master cylinders from Tilton series-78 to series-79 to get MCs that are ABS compatible.That is interesting. I assume the two lines going into the distribution block are F/R brake lines from the master and the 4 lines on the top are to the 4 calipers? Does the yaw sensor and wheel speed sensor data go to a separate control module? Does it control all 4 wheels?
