Nice clean work. I have to cut the trans tunnel in my car and have been using an air saw. Works OK but its slow and wanders. What are you using to cut the firewall?
I had to put the differential in to make some measurements to align the motor as I build new mounts for it. I bought a Harbor Freight trans jack for $136.00 and it sure made lifting the differential into place easier. The DSE hammer head diff. is aluminum, but it's damn sure not light!
Setback motor looks great! You are behind the front axle line, and then some, no?
Will your exhaust exit at the rear? or a side/dump?
BTW, did anybody notice the "up-angled" tail pipe exits on the C 8R? Looks like they are doing that to create a low pressure area above the diffuser to help its efficiency.
Yes, sort of a jet ejector principle. Some call it a jet pump. They even sood a leaf blower with an ejector attachment, not sure if they still do.
What did he charge, if you don’t mind if I ask. Was it lighter than chromoly ?
I’ve bought some yokes from them and they are very nice.
