big2bird
Over greasing the bearings is just as bad as under greasing them. Over greasing will cause excessive heat on the bearing until it leaks eventally leaks out of the seals. Mechanics that use to work with would pump bearings full of grease until they leaked out of the seal. That was the only way they knew grease was actually getting to the bearing. The next day operations would call complaining about the bearings were running hot and suspected there might be bearing problems. There would be a pile of grease looking like a turd sitting below the housings. Better safe than sorry!:lol:
Sometimes REAL WORLD experience TRUMPS mind boggling theory.
