Carburated Nihilist
Looks like a Countach to me :nuts:Just curious: what's the car behind the vette ?
Looking good so far, door jambs are a little time consuming with all the tight spots behind the fender...
I've been contemplating this color for my vette too.Originally I was looking at the Harley Gun Metal and this is pretty close. I wanted the darker gray not silver. I think its a new color for the C7. http://www.corvette7.com/forums/showthread.php?t=280128
Is it commercially available?
I heard it uses a brand new pigment only made in Japan and they were out of stock not so long ago.
I was under the impression GM would keep it a C7 exclusivity, but it's just an impression.
Finally getting around to fitting the tru flex bumper. Thought I would tackle the front first. Its not even close to fitting. Called the company and they suggested I cut it in half and fit the corners then rebond the middle. Since my vette was previously wrecked on right front corner maybe the fender line was not reshaped correct but it doesn't line up very well on the driver side either. Its seems to be about 1/2 to 5/8 inch to wide. I drilled a few mounting holes and installed a bout 1/2 the fastners and got it close but not enough. Think I will try and send this bumper cover back or sell and get a real fiberglass bumper cover.
FIY the pigment I was referring to is Xirallic, it's supposed to give a distinct shine.I've been contemplating this color for my vette too.Originally I was looking at the Harley Gun Metal and this is pretty close. I wanted the darker gray not silver. I think its a new color for the C7. http://www.corvette7.com/forums/showthread.php?t=280128
Pretty much any color can be matched, just take one part in that color to the paint shop and they should be able to match it. I did however notice that a gallon of PPG DBC basecoat that is usually 300-400 dollars is now $800 on Ebay because it's a C7 color......
So they said you need to cut a brand new bumper to make it fit? I'd be pissed and I'd probably call my credit card company and refuse payment.... :smash:
1/4" is somewhat acceptable but 1/2"-5/8" is just ridiculous.....
On the "good news" side: fiberglass can easily be fixed ...
Really leaning towards seamless. I really like the clean look and can't wrap my mind around how there could be a visble seam down the road, if I grind them out and fill with resin and glass mat.
Would this be a good application for Evercoat Panel Adhesive #870. Have some of this product on hand.
No. Evercoat Adhesive 994 is for SmC, google evercoat smc adhesive, think it was 994 or 944 , wit 944 is a Porsche......lol
Seriously: the evercoat vette panel adhesive clearly says "for non-smc material" , means fiberglass.... Your bumper is fiberglass but the fenders and nose is smc if original late 70's
I have used the Evercoat smc adhesive - awesome stuff .... Used it to glue the rear flares to the smc quarters, been 8 years, no issues.....
