i......- I wonder if I get rid of the hop then find the weakest metal in the frame when it gets torn out.... they don't call it the bleeding edge for nothing :banghead:
I recall one guy had cut gussets out of thick steel for every corner of his C3 frame and reinforced everything. for sure you are pushing the limits on horse power, and beefy tires .....maybe if things keep breaking you go to less traction on the tires and do more burn outs instead.
I'm hoping that adding lightness is going to help in this arena.. to remind, I'm 600 lbs less then shipping weight
Have you looked a fabricating adjustable toe links using round tubing and heims? Several companies offer them for the Camaro suspension. Here is an old post from Apex Motorsports:
"Toe links are one of the critical components in reducing/eliminating wheel hop and improving traction. The wheel hop "trifecta" is sub frame bushing, trailing arms, and toe rods. Each contributes to limiting/eliminating some portion of the the movement and deflection that causes wheel hop. Toe rods fight the deflection that causes toe changes in the rear wheels under hard acceleration. This deflection reduces the contact patch of the rear tires thus reduces traction."
Pappy
Those are the $396 option I mentioned before... the toe is adjustable already - it's the same cam system as the Corvettes... and I know, they're hated by people who can't tighten a nut
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
not to be mean or anything :lol:
There is, also, kind of another reason I'm not doing the tubular options. The rules say "stock attachment points and stock arms"... pushing the envelope here could be a problem.... I didn't look close enough at the GTV class cars at SEMA 2019 to know how enforced that rule is....
