it wasn't easy. Do you have the wheels you plan on running on the car? everything lines up off that - because the flares are pretty thin, you can use heat to get it to relax enough to move. Outside of that, I had to cut the flare from the rest of the fender and move it forward on the front to get everything to line up. If you're having too much trouble getting the curve right, you may have to section the flare to get it right..... also, contacting Josh at CIC for tips is available.... while I have some annoyance at my situation, I think he does his best and is quite helpful
Well , I have the rear tyres and a device called a "wheel fit " which is an adjustable bracket which clamps onto the tyre and is bolted to the hub , but is adjustable . (so you can get the right backspace and offset you need ). I haven't got wheels yet as I still have to do this to the front.
Anyway the tyres fit really nice on the back as is. Only worry for me is suspension travel (settle) between now and when its all back together .My suspension is unloaded now so I set it at full low (transverse spring at rear ) I have a heavy rated new one coming from Vansteel soon , I got it shortened and its supposed to be about 480lb . Motor ,g/box ,doors (loaded) , empty fuel tank are on the car now.
I tried a heat gun on the offcuts , but I think I overdone it in a too small an area . It just fractured everything as I tried to bend . I will play around a bit with that again on some wider off cuts . Thanks for the advice .
