SuperBuickGuy
choices.
The A1000 pump is good for 1200 hp and has -12 lines in and out. The Holley system right now has - 6 lines and makes 500 wheel hp
I've been going back and forth about upgrading lines. I have most of what I need to upgrade to -10 supply and -8 return.
But
at this point I'm already pushing noise limits and 700 hp is at 7000 rpm. As it is now, it's got a physical cap on noise - set the rev limiter to 5500 and life is fine.
But yeah.
my only real concern if I leave it all -6 is it puts a lot of stress on the pump but with that said, I can turn the pressure up to 75 psi if I really want more power... after all volume is a function of pressure
got more done tonight, though.... think I'll stay with -6 for now.... but when I build more power, I'll update. At this moment, the car is fast enough for my skills.
line test
![kDNpv6b.jpg kDNpv6b.jpg](https://data.vettemod.com/attachments/52/52131-984ce6356f261aea67e44d5a3e9002aa.jpg?hash=mEzmNW8mGu)
starting to lay out how the tank will be mounted
![xVfBbBD.jpg xVfBbBD.jpg](https://data.vettemod.com/attachments/52/52132-df63dbe18aa11491e83e2606717094a8.jpg?hash=32Pb4YqhFJ)
I also need to put an offset in the fill tube to line up with the gas cap (3 7/8 offset)
![19DWXfL.jpg 19DWXfL.jpg](https://data.vettemod.com/attachments/52/52133-dd979e8b3e3216e0f85a5ca98d780536.jpg?hash=3Zeeiz4yFu)
I also welded in the braces - brackets got a coat of paint so drying... bolts get here Friday
But
But yeah.
line test
