Now there's a thought- figure out how to GENTLY pressurize the crankcase and get out the soapy water. 1 or 2 psi should be plenty. Some duct tape and rags should do it.
Yea the 1 piece Fel-Pro blue broke,so i have to go get another one,hope the part stores have one, the 1 piece blue.
We use the Corteco gaskets which is the oil Detriot gasket with a little work, This gasket is a much softer gasket and will not break. 16635 P/N
Just can't have anything nice:banghead::waxer:
If you have oil around the cam plug then you can bet it's leaking. Why not just change it while it's available.
Here is the best 2 piece rear seal.
Fel-pro FFP2912 Red Fluoroelastomer, Offset
Here are the 100% oilite pilot bearings. Should last thru several clutch changes.
Gm Oilite P/N 3752487
Napa Oilite BK-6151161
GM Needle P/N 14061685
I remember you having oil problems before and you came up with a creative pcv system. It might be worth testing that. No seals or gaskets in the world will overcome constant positive crankcase pressure.
You may take a good vacuum/pressure gauge and tape it into the dipstick tube so you can test the pressure under various rpms with your pcv system operating.
