Belgian1979vette
Can someone here provide me a list with parts and (if available) partnumbers to do a DIY rack and pinion conversion ? Thx
A couple of questions after reading up on the subject :
- I see that the colums sticks out fairly long and so the angles to get to the rack maybe pretty sharp, causing issues. Don't want to cut the motor support and don't want to shorten the column either, what are the options ?
- any issues using different length arms when the rack is offset ?
No issues with the arms, the center link takes care of that - you can weld the center so that the arms (tie rods) are the same length.
For the input shaft: I didn't like the idea of having three U-joints so I cut the frame horn, after welding the half pipe in there it's stronger than it ever was so no worries here ... I don't see any other options, cut the mount, collaps the column and it's all good .... I still have to check what's wrong with my setup and why there's slop again. I don't want to blame the rack until I inspected everything else .... Although at this point I believe it is the rack ...
Hey man, dunno if you aware, but those racks have an adjustment screw to push the rack into the pinion just a bit, that is the 'slop' adjustment, take a good look around the pinion input position and spot that bolt.....it's not much of an adjustment, turns wise, so be careful......:clobbered:
Damn I had no idea ... That would be a easy fix .... Thanks !!!
