turtlevette
The Turdle
How do you secure the nut? Do you tighten it a little more to get the pin in or loosen it? What about bearing clearance ? I'd think it's either too tight or too loose since you have to turn the nut to fit the cotter pin ... not ?
I don't see anything wrong with it either except that IF the spindle breaks (which is not very common to my knowledge) the only thing holding the wheel on the car is the brake caliper....
I believe that if GM can save a penny they do, they even save a fraction of a penny and use Velcro instead of a plastic clip to hold a fuse panel cover on the dashboard (4th gen F-body).
They would NEVER make it a press fit if they thought it wasn't necessary. :smash:
you do the best you can to zero clearance it just like the front. The front has two cotter pin holes which helps alot. You can use valve spring shims or other appropriate shims to get it just right.
The brake caliper is enough to hold the wheel on until you coast down. Most of these spindles break on clutch dump launches anyway so you aren't moving fast. I haven't broken or even twisted a spindle in 28 years of driving, so i'm not worried about it. It really simplifies maintenance in this area. If i'm up in Canada and burn a bearing, i can just pop some more in in an hour or so.
Almost everyone modifies or bypasses many safety features on our cars and nobody bitches about that.
I go around the car and push on the top of the tire routinely as a habit. Its one of the things they do when they tech the car. The side that is hand tight with no spacer has no detectable play at all. I have at least 75k miles (did it 6-7 years ago) on that hand tight setup and its not getting any looser. That's more miles than 90% of C3ers will put on the car in a lifetime.
The whole point for me is to save a bunch of work. But more importantly not to get stranded by a rear bearing. I suppose the other thing a person could do is just carry a spare bearing housing and spindle already setup and just pop that in. I know they are left and right but the difference is subtle. You can take a shock mount and extend the flat with a grinder the whole length so it fits either way.
