hood scoop
Hood scoop
I finally decided on a C4(ish) hood scoop - adds about 1 1/2 " of cowl space without completely blocking the window... so - time to install
Measure, the centerline is absolutely the most important thing you can find
When you have complex shapes, finding the center can be a challenge - sometimes you have to come up with a tool to measure...
what seems to be the center, isn't
center mark the hood
(incidently, this will cure the a$$ and foot marks in the hood - woohoo)
using a calibrated eyeball, I penciled out where the first cuts would be
as an aside, I used blue tape because this is a porous fiberglass scoop - if I marked it with anything, it'll suck into the scoop and bleed through when I paint it
and cut
out come the zip screws, and down goes the scoop
looks good, and most importantly it's centered and the horizon is the same on all points
no going back now
I briefly thought of plexiglass in the hole, but no, only hemis look good under glass
so it's cut small, time to trim
took a break and eyeballed what the cold air will look like
looks the same as above, no? actually, no, the scoop is now screwed down where it belongs
side view
I'm certainly no Dulcich, but I like how it's turning out.... of course, this was the easy part - making it solid is going to be a bit more difficult.... except I'm going to try something a bit new(er), and epoxy a lip to the hood, then epoxy the scoop to the hood. Once that sets up, I'll fill the gap with resin then bondo the top.....
