turtlevette
The Turdle
So, when I put my AFRs on, I should go with MLS over other types? Price-wise, copper is in the same ball park as the MLS. Why would MLS be better than copper? Or for the difference, should I go with copper instead?
What about just plane single layer steel gaskets?
I'm thinking the next time i replace blown head gaskets or finally do the all aluminum SB1, i'll use copper with the precoated silicone around the water ports. I believe they're around $100 each but worth it to avoid teardowns because of blown head gaskets.
I have not had good luck with Fel Pro blue. They don't have enough metal reinforcement in the fire rings between the center 2 cylinders. I used the GM ZZ graphite gaskets last time and there was much more metal between the middle 2 cylinders where it always breaks.
My philosophy is that metal is much tougher than composite or rubber. I mean, that stuff looks like cardboard. It's sort of intuitive.
I'd go with solid copper over thin metal sanwiched between rubber.
