because then I would need a different length belt and I have a bunch of these belts as spares. I can't just go to the vatozone and get a new belt here.
There is absolutely no issue running it like this. The grey camaro has it, the black gta, nmy truck, Joops 88 camaro and his 82 trans am. No issues on any of them.
I put a ZZ4 in my 68 and installed a GM Performance Parts catalog serpentine belt drive system...
All that is, is a over priced f-body serpentine system
A/C with these brackets uses the "pancake" style compressor, which I believe was also used on later C3s.
I think the CS144 adapter bracket was a stock police car part. I ordered from RockAuto, if memory serves. It still took a bit of modification before things fit right. There may be some pics at CF, if I ever took any.
I have a set of the steel braces, but I've never installed them and the alternator brace doesn't want to fit with the CS144 anyway. I'll have to do some digging around online to see if the Caprice police cars used a different brace. They aren't totally necessary, but GM put them there for a reason.
Thanks again. I was hoping to do this without having to change AC or alternator since both are fairly new on my '73. Looks like one of the pancake style compressors may be mandatory. As far as the CS144, maybe I just need to source brackets from a Caprice or other car that came stock with one. Here's a list of those vehicles per RockAuto if anyone needs it.
ACDELCO 3351048 Alternator:
BUICK ROADMASTER (1994 - 1996)
CADILLAC FLEETWOOD (1993 - 1996)
CHEVROLET CAPRICE (1993 - 1996)
CHEVROLET IMPALA (1994 - 1996)
CHEVROLET LUMINA APV (1992 - 1995)
OLDSMOBILE SILHOUETTE (1992 - 1995)
PONTIAC TRANS SPORT (1992 - 1995)
DC
DC
I have switched alts between the CS and SI series with no problems on the mounts, easy do.....
trick is, the fore/aft pulley spacing, and in all the updates, I have never done anything more than line up the pulleys with a straight edge and maybe a flip over on the alt pulley, and some large washers for spacers....hammer home and done deal....
:gurney:
The 144 is significantly larger than the 130 (or 133, whatever the smaller CS is).
I think only the police-spec Caprices got the big alternator. It's been years since I bought that part, I forget the exact interchange.
It was at least an option on all of the vehicles I listed above. I sourced mine by specifying a '93 Cadillac Fleetwood at NAPA. They had it in stock. Had to clock the housing but that was it.
Does anyone know if all of the serpentine options discussed place the AC compressor in front of the head? If so, then I will definitely need one of the pankcake style compressors as the VA one looks to be too long to fit in front.
DC
Refer to this article:
http://www.carcraft.com/techarticles/ccrp_0911_serpentine_belt_drive/viewall.html
A very nice setup but the idler wheel setup in the AIR-pump-bracket will not fit the C3 without modification.
Arne
I was specifically referring to the Caprice line, and the bracket to mount a CS144 where a CS130 would normally be found on that set of serpentine brackets.
