T top question...
I will be sticking my frames back to the tops soon but what should I use to do it? I spoke to a T-top rebuilding place some time ago and they said that they use urethane adhesive when sticking glass tops back onto the frames but obviously they had no experience with steel tops. Would urethane adhesive be ok to stick my steel tops back on?
Saudi ... it will work fine. Be sure to use the pinch-weld primer on the metal
before applying the urethane. Think about this logically .... a windshield is
glued to a steel pinch-weld so why can't the opposite also work ... :)
The Pinch-weld primer is intended to be applied to bare metal .. then apply
the urethane ... I would recommend you use a High Viscosity Urethane like
that used on modern car windshields.
