TB5 and TB15
84rzv500r
Knows just enough to be dangerous!
Big Pine Key, FL
anybody have experience with Michelin TB5/TB15 raidials..
I am getting closer to finishing the Canam 502 project and while i have been happy with the Nitto 555R's the treadlife has been less than 6000 miles a set.
I am looking to go a bit wider and lower profile and longer treadlife for what will be more street oriented use as i move further south... the Nittos are ok when new in the wet but fall off within the first 1-2000 miles
the TB series are a bit expensive but are lower profile and wider than my current 275/50VR15 and 325/50VR15 fitment and have two compound choices
and I refuse to go to 16/17/18/19/20 inch wheels as i dont like the look at all...
thoughts?:mobeer:
Tire, Coker Michelin TB15, 335/35VR15, Radial, Blackwall, Each at summit racing now !!
Tire, Coker Michelin TB15, 270 /45R15, Radial, V Speed Rated, 86 Load Range, Blackwall,
there is a 295 as well but i dont think i can get them under my front flares without crowding the inside with more backspace...
a cool $2000+ set of tires
less sidewall and about the same sectionwidth and a little more rear treadwidth and i will have to adjust my rear spring links or maybe just rais the differential an inch but it will lower the rear of the car 2" and the front another inch:smash::eek::twitch:
:D:D
