Temporary rolling the car, 1/2 shafts needed?
keep in mind I'm using my calibrated eyeball (good for +/- 10' or so) to judge that the tire won't hit at the top when you ratchet the two arms toward each other.... however, your results may very and could cause impotence.... The trick is make them flop the way you want them to go, then control that flop to keep it from happening while you're moving it :thumbs:
The amount of flip is dependent on the angle of the dangle, and that's the way the mop flops......:harhar:
While that may be true, I'm not getting anywhere near your dangle to measure its oscillation and incidence
I had belly button surgery last Friday AM, so there is nothing going on there now, for sure.....outpatient, so home around 2 on Friday PM....:hissyfit::crylol:
