Belgian1979vette
In another thread i posted about a problem with 3M 08115. The reason I'm posting this here is to warn about possible problems with its use, namely shrinkage and swelling.
I used the 8115 not only to glue my parts to the birdcage, but because it was advertised as usefull for bonding fiberglass and SMC, I also used it to bond a new fender to my car. Since I believed it was hard enough I filled some smaller srewholes with it and also filled the bond between the fender and hood surround with it, aka the original way the car was put together.
The pictures below show what happens when it gets heated, like when the car sits in the sun for example.
The first picture is taken before heating with an hairdryer, the second after, and the third after cooling. Notice how the seam appears when heated and disappears again after cooling....
The 8115 even starts to produce bubbles underneath the primer when it gets hot enough.
Anyway, I'm looking at substantial repairwork....when I discovered this problem I had a serious headache as a result...
Luckily I caught it before it got painted.
I dont think it will harm anything when used for bonding parts to the birdcage for example, but you sure as hell cannot use it underneath a painted surface.
Now I have to find a good way to redo everything....damn
