DC3
Don't just go by the dollars.  Rates and fuel costs for power companies can change monthly.  Compare the actual energy consumption (kWh).
Another thing you can do to factor out changing weather from month to month is to visit the National Weather Service website for your location. Somewhere in their climate data charts should be data for "degree days". Basically a degree day is a way to account for heating and cooling needs based on the average temperature of the day and how far that average temperature is from 65 degrees. If the average temperature is above 65 degrees, it is called a "cooling degree day" (CDD) and if the average temperature is below 65 degrees, it is called a "heating degree day" (HDD). For example, if the average temperature for the day is 85 degrees, there are 20 cooling degrees in that day. And if the average temperature for the day is only 55 degrees, there are 10 heating degrees in that day. The National Weather Service site should have the degree days by each day. You can add up the numbers for each day of your electric bill and then compare month to month to see how cooling needs have changed for your location. If the cooling degree day total goes up 20% from one month to the next, you can expect about 20% increased air conditioning usage (which may translate to less than 20% of the total bill because of lights, refrigerators and other normal usage).
You might also touch base with your power company as they might already know the degree days associated with your billing period.
I helped a lady recently who had super-insulated her house earlier this summer (late in the spring actually) but was disappointed with the results. It seemed her consumption had not changed any after the first month. I helped her realize that the cooling degree days had increased 50% from her "before" month to her first "after" month so the fact that her consumption was the same was a good indication of the benefit she received from better insulation. As it turns out, her consumption for the summer is way down compared to the summer before with similar degree day totals.
Hope this helps.
DC
Hope this helps.
DC
		 :mobeer:
:mobeer:
