mrvette
Phantom of the Opera
I'll remember that Jeff, thanks.Hey denpo, if you need a 90-91 Camaro SD harness for cheap let me know. It has like 3 cut connectors for the distributor but a real easy fix. This harness even has the wiring to run dual electric fans.
was going to use it on my 82 vette but have decided to just keep the crossfire on the car.
So a MAF based computer can be retrofitted to handle a MAP sensor/harness?
NO, there are 2 different computers, you SEEM to have a MAP based computer next to the rails/brown box in your pix there....should be marked 1227730 the other computer to the bottom left of the pix, looks like one from my '87 vette, and is a MAF type computer....
now here is a trick, the computers will need reprogramming , to remove the security key crap and you are going to need the wiring from a '91 F body....I MAY still have them on store in my computer somewhere, and can send in email, if not, I can copy them and send in a email.....
that will be a MAP system, like I have had for 16 years now....
:smash:
