SuperBuickGuy
AUJP = a 5.7L L98 Auto prom, that's a speed density setup.
You do know you will have to get a bin with VATS disabled right?
I should have the ARAP bin somewhere. Would be best to tweak the bin for the correct axle ratio too. What kind of injectors? Looks like painted multecs? I would change them right now, easiest to do with the engine out of the car. Get some modified Bosch IIIs from southbay. They are a day and night difference with those junk Multecs.
I am just wondering if someone could provide an English translation?
I bought the motor with the set up that should be all ready to run. It came with the sensors and new wiring loom. The injectors are Accel 23lb. This motor will be a DD so I was not looking for something to go racing. The engine builder sells these setups for mostly street rods and they are sold ready to run, What I need now it a wiring diagram in order to connect all the sensors correctly.
Maybe later after getting into this I will understand more than I currently do, which is very little.
english translation - you're screwed.... no seriously
In order to get the proper schematic, we need to know what car that motor and associated wiring harness came from. The discussion about type of injector, MAF, MAS, or Speed density is the same as asking what year that injection was built. The other advice you're getting has to do with reliability and the ability to start the car.
So. What year did the builder claim the fuel injection was built? Schematics are actually fairly easy to get; but honestly, Painless wiring makes a harness that simply requires ignition power, full-time power, and a ground to make it run.... were it me - I'd go that route.... However, this would not be complete without an example of the number of wires you might be dealing with
to make this project car of mine run, I simply have to connect the wires on the right and left to the wires in the middle (57 for those who are curious) :crap:
