JeffP1167
The 90 ecm going into the car will be needing the vats signal anyways and being the top will be off the car a lot. So figure vats will give me a little peace of mind.
You'll need more than the chip key. GM also used a module in the dash to proved a 50hz signal to the ecu as well.
I've got the VATS schematic for 85-92 f body if you need it.
I have been using 1227730 in my '72 vette.....it don't take any decoder module it's wired like a '91 firebird V8.....aftermarket chip....
:smash:
Your chip has VATS disabled, he wants to keep it.
:smash:
:smash:
I know, I offered suggestion as to what I did in place of the troublesome VATS system, it has a poor reliability reputation, I had it bypassed in the chip on my '87, :surrender: and of course on the basic TPI setup on the '72 now....
:smash:
My 97 camaro has vats and it has never been a problem, but I replace my tumbler set which is where the heart of the problems are every 2-3 years and I have never once had a issue. What 60.00 in 2-3 years...
:smash:
So you are putting forth the concept of installing a trouble prone stock system into a early vette so the VATS works as designed, I never did consider it for my '72, and it has a '78+ shark TT column installed in it....
so would be the same as that '82? in planning here....why bust a nut over it when other options like I outlined above work much better, as there is NO auto thief going to tear the entire car apart of steal it....hell I leave the keys IN it at cruise nights....knowing full well it not going anywhere....
:clap:
Part of the effectiveness of VATS is that thieves knew which cars had it.
If you want to keep the disable feature though you could just skip the chip key and use a VATS bypass module. It's just a 30 or 50hz generator you can plug in somewhere in the car. Pretty easy to make yourself too. You would have to bypass the starter disable though.
But if you're going to do that, you might as well just install a hidden kill switch.
