mrvette
Phantom of the Opera
aluminum master cylinder - minus 5 pounds
brake system (includes titanium rotors, aluminum calipers) - minus about 100 pounds (these are not on the car yet but will be soon)
Could you state where you got your titanium rotors and I assume aluminum hubs? Is the aluminum master cylinder from SSBC?
Also, what about getting rid of that large iron casting that connects the steering column to the bottom of the windshield frame. It's really gross. Also it's high above the center of gravity of the car to make it worse.
Seems like someone could fabricate some aluminum plates and weld/bolt them together to make a functional replacement.
Later sharks have a sheetmetal version of that casting....I have not changed mine out yet....but someday....probable savings over 5 lbs right there .....
:stirpot:
