69427
You haven't identified all the weight reducing things you've done .. I've always been interested in you weight reduction postings. ..................
Here's the stuff I can think of at the moment. Starting from the front:
Aluminum: radiator, support, lower crossmember, and side brackets.
Aluminum (c4) suspension F&R
Tubular front sway bar
Two piece lightweight Wilwood rotors, aluminum Wilwood calipers
Aluminum wheels, of course
Aluminum hood hinges
Aluminum engine stuff and lightweight L-88 flywheel, PMGR starter
Lightweight alternator and aluminum bracket
Lighterweight p/s pump and aluminum bracket
Aluminum shifter handle
Lighter weight '79 seats and aluminum brackets
Lightweight battery (16#)
Late C3 batwing with C4 leaf spring
Aluminum Wilwood calipers
Aluminum rear bumper brackets
That's most of the stuff I can think of at the moment. As I mentioned earlier, my goal is to remove weight but keep a stock appearance.
