Once I get my return line hooked up I am hoping that will eliminate the vapor lock issue. But if it doesn't the next step is an electric fuel pump to assist the mechanical. Does header wrap make any difference? I already have Jet hot coated headers, HV water pump, dewitt radiator and dual ouller fans. What else are you guys doing to reduce heat? Should I use some tape on the headers?
Wade
Wade
