elevatordude
Should I cut the crossmember and make it removable and if I do end up cutting it would anyone have a template for the plates?
Thanks Ray
Thanks Ray
Why not buy the correct brackets and x-member for the auto's and weld them in?
I love that idea, but I wonder what something like that would runI couldn't make that with the tools I have and I cant weld... Maybe I'll just hot glue them on :idea:
Any updates on the removable crossmember question. I've got a TKO-600 tranny on order from Kreisler. I'm going to put in in the 68. Right now with the stock Muncie, its 3000 rpm at 70 mph...arghhh. Really sucks gas and also I hate to think of the engine wear and tear.
A previous posting has a sketch of some plates. I don't know where, as of yet, to have them fabricated here in LA. I also have an auto tranny crossmember. Part of the frame attachment brackets are included with the auto tranny crossmember...but not all of the brackets...someone cut off the attachment brackets with a cutoff wheel and a portion of the brackets were left behind on the frame! I worry about trying to use the auto crossmember since if I have it welded back on (i.e. weld what's left of the frame attachment brackets) and it's off a little in elevation, I could have driveshaft problems. I think I like the plates better.
Maybe 10 years ago, Guldstrand Motorsports in Glendale, Ca wanted $1500 to build a removable crossmember for the 68. I'll probably give him a call, but I bet the price is more now. Even 10 years ago, or so, $1500 seemed really pricey.
Thanks
Heres a few While I'm at it...
Plates
Cutting
Spot welding of plates in position.
Everything in place
Frame gussets
Box the engine support
Rear safety loop connections.
Safety loop
Cardan shaft and loop. The distance around the shaft to the loop is 8mm (5/16"). It should be enough to allow movement of the driveline during driving. If not, I will make a new loop.
Ready!
Anyway theres more on this on this thread from 427suede,
http://www.vettemod.com/forum/showthread.php?t=7724
